Turning on part planes in an assemly
_4271_4271 Member Posts: 1
Perhaps I'm going about this the wrong way, but I'd like to use an existing plane in a part to create a section view within an assembly. Ideally I'd like to turn on a parts plane in assemly studio, so that I can select it to use as a viewing section. Does that make sense? I know it's often not a problem and you can drag and rotate from planar faces. But sometimes a lot of work has gone into creating a plane in an organic shape and it would be great to just pick that plane to section the assembly.
Thanks in advance.
  • stanneedlestanneedle Member Posts: 2
    Inserting a surface seems to be no longer an option.   I have only revolved parts, and the mates only show planes that are perpendicular to my central axis.  I can't seem to make a section view along the axis.
  • IsoworksIsoworks Member Posts: 22 PRO
    Well this doesn't seem to work there is no "third choice" in the insert area - parts or sketches.
    Frustrated.
  • paul_chastellpaul_chastell Onshape Employees Posts: 126
    From that I infer that your document doesn't have any surfaces in it. If you share a link to your document someone may be able to offer more specific advice. Note that the default planes are not surfaces.
    For example, here is what I see when I only have parts (no filters):
    Here is what I see if I have both solids and surfaces (the filters appear):
    And if I go to all surfaces then the filter again disappears.
    And here's an assembly with a surface inserted:
    Paul Chastell
    TVP, Onshape R&D
    Dropping in here because no one has mentioned how to actually make these surfaces in the Part Studio.
    The easiest way to make a surface representing any plane in your part studio is to make a rectangular sketch on the plane in question and then do an "Offset surface" of that sketch rectangle with an Offset value of 0.
    https://cad.onshape.com/help/Content/offset_surface.htm
  • mahirmahir Member, Developers Posts: 1,315 ✭✭✭✭✭
    edited March 2018
    And if all you have is a plane with no solid/surface geometry to Offset, use that plane to create a dummy sketch that can be imported to the assembly. That sketch can be used to create a section. A surface will work, too, but AFAIK there is no way to directly create a surface on a plane that is simpler than just creating a single sketch.
  • mlaflecheCADmlaflecheCAD Member, Onshape Employees, Developers Posts: 181
    edited March 2018
    Dropping in on two more options that I like using:
    Mate Connectors come in from the part studios which make snapping parts together really easy.  https://learn.onshape.com/learn/article/advanced-mating-techniques
    Also inserting sketches from the part studio is really a useful technique for layout modeling as Mahir mentions .  https://www.youtube.com/watch?v=Rvu9763-2I4
    Regards,
    Mike LaFleche   @mlaflecheCAD
