How to display the screw?
dragon_chen_dragondragon_chen_dragon Member Posts: 22 ✭✭
  • MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,062 ✭✭✭✭✭
    @dragon_chen_dragon
    Is that solidworks?
    edited March 2018
    @dragon_chen_dragon are you asking how to display the threads of a tapped hole?
    Or are you asking how to insert a screw or fastener?
    To inser a fastener you can do a couple of things:
    - Import a fastener into an assembly
    - Model the fastener in your part studio
    - Insert a fastener via standard content in an assembly.
    To display the actual threads of a tapped hole you will need to model those with a helix sketch, thread profile and sweep.
    Currently there isn’t an easier way to display internal threads.
    If you use the hole tool to create the hole and threads, when you create a drawing you can use the hole callout tool to “display” the threads in a standard format.
  • petr_svobodapetr_svoboda OS Professional Posts: 8 PRO
    edited March 2018
  • dragon_chen_dragondragon_chen_dragon Member Posts: 22 ✭✭
    It's not solidworks, Made by Inventor. It doesn't real screw. let me distinguish between different hole in 3D.
    where the Decorative thread display that I can find it?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,895
    Hi @dragon_chen_dragon, there is no cosmetic thread option in Onshape. Please create an improvement request in the category on the right ->
