How to extrude a sketch, touching the edge of existing part
kvdmolenp
Member Posts: 28 ✭✭
Hi,
I'm trying to extrude a circle to a solid, drawn on the shape below.
But I can't select the circle! Only the entire shape like the yellow below.
The drawing's face is the face of the part. The circle is visible.
Any idea how to achieve this?
Something about ambiguity in touching edges?
Thanks!
Thanks!
If you created the sketch just as an arc, it won't select. You will need to create the sketch as a circle
