sheet metal couldn't Union to a part.
dragon_chen_dragondragon_chen_dragon Member Posts: 22 ✭✭
  • michael_mcclainmichael_mcclain Member Posts: 198 PRO
    My first guess is that you have to finish the sheet metal part to boolean. In the sheet metal toolbar, the symbol on the far right is finish sheet metal model
  • bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 373
    I agree with @michael_mcclain. If you are trying to retain it as sheet metal component you will have to add a bend between the two edges you want to join, not use the boolean feature.
    Twitter: @bradleysauln
  • dragon_chen_dragondragon_chen_dragon Member Posts: 22 ✭✭
    I try to finish the sheet metal part to boolean.Doesn't working.I just want to combine sheet metal.get one part number.
    @dragon_chen_dragon - did you "finish" both sheet metal parts? Do they physically intersect? If they are really a subassembly, then you should add them to an assembly to have them appear as 1 item in the BOM.
    It's working.thank you very much.
