Sketch Offset gives correct preview, but then fails
Little tricky to explain with words so, here is a pic.
What is the underlying sketch? It is a projection on another sketch of a FeatureScript skFitSpline + skLineSegment (no skConstraint between them);
I try to offset this closed curve and here what happens:
1) I select the entities that I want to offset, and the spline is correctly extended
2) but the Sketch is not solved correctly after that
Any reason why?
Any reason why?
Thanks Dario, you helped me remember to show this dificulty.
@terry_falldorf, please submit a support ticket the next time you encounter this. I haven't encountered this issue personally, and tickets provide us with some additional information that can be useful for reproducing bugs so that we can fix them.
It sounds like you are describing a problem I had with offset for a long time.
When you drag the line you must get off to the side of arrow so it turns white, not orange. Then it will consistently remain in direction you desire.
Note this screen capture; first I do it incorrectly with arrow orange and the offset bounces back and forth. Then I do it correctly, dragging to side of arrow so it is white and offset stays where I want it.
I am using Chrome on Win 7 Pro.
I will also open a ticket.
