Different values ​​for the variables following the configuration
Hello,
I want to be able to assign to a variable different values ​​for the default, minimum and maximum values ​​depending on the different configuration choices. Is it possible and how ?
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,232
    Sorry, all the configuration inputs are independent.  The best I can suggest today would be making a custom feature that checks whether the combination of all the configuration tables and inputs is valid and fails the Part Studio if not -- that way you'll at least know you won't insert an invalid configuration into an assembly or drawing.
