from mesh to solid? possible?
franco_otaola
Member Posts: 23 ✭
in General
hello,
i wanted to use the model of a hand to make a 3D model that adapts perfectly to the hand curvature, my problem is that i found a free 3D model that is a mesh, so i cant use it in a assembly to be able to edit in context or use the volume of the hand to subtract the volume of it.
is there any possibility to make a solid from the mesh? or at least a surface (or each surface between each point of the mesh) of it ?
thanks a lot
thanks a lot
