Drawing a mould flange on a revolved face
HI, Getting there.
I have created a few revolved entities, They for a two part mould. I would like to create side flanges on the sides of the mould piece. I need to know how to draw on the face of a revolved face and then make it conform to the center plane.
michael_mcclain Member Posts: 198 PRO
john_mcclary said:Here is a short video, of how to join those easy:
https://youtu.be/mLNFdAdPw-M5
https://cad.onshape.com/documents/99c1382b58c6245bb748a26e/w/76595707949455f677922b54/e/94fadfe03a8b8fccd96ade03
https://www.onshape.com/featurescript
With your situation, I would suggest modelling the whole piece in one part studio. Make a master sketch with all the necessary features taken into account, then use portions of that sketch for individual features. The model tree would look like this:
Sketch1 (Master Sketch)
Revolve 1 (Main Body without inner cut)
Extrude 1 (Flange Extrude)
Revolve 2 (Cut from the main body to obtain the inside profile)
This method adds all material first, then you cut the inside after. Ill make an example for you when I get time.
If you have troubles with anything I would suggest to look at the learning center, the help page, or the video library. There is an abundance of free learning resources offered by Onshape.
Out of curiosity, what is your native language?
Check out this document. I created 2 sketches, one for the main body and the main cut, then one for the flange and used portions of them for different features. I added the Main Body and the flange first, then cut the inside afterwards. Let me know if you have any questions and Ill be happy to answer them.
