Is it possible to set a minimum & maximum value for a sketch dimension ?
francois_boulet
francois_boulet Member Posts: 65 ✭✭✭
Using variables or otherwise, is it possible to set a minimum & maximum value for a sketch dimension ?
Giving different values to some variables affecting the mentioned dimension, I want to be able to choose the value of that dimension and make sure that the result will stay between some defined limits.
The link:
https://cad.onshape.com/documents/6de388c6d4ffa687115fa4a3/w/c2519130b0ffff206097bbc8/e/997c32e1b83badc941474d66
Included; the Part studio and a PDF
The real question might be: Is it possible to have a conditional value in the last part of the formula ?
La simplicité est la sophistication suprême.
Léonard de Vinci
  • francois_boulet
    Thank you guys !
    Thanks for your first link Bruce.
    It lead me to Brian Brady's comment:
    You can also nest conditionals by placing another complete conditional statement in either the true or false positions. I suggest using parentheses around the second statement (may even be necessary) for readability.   #width<4?1:(#width>4?3:2)
    Now I can say:
    It is possible to set Min & Max value for a sketch dimension using variables and conditional expression. (See the updated PDF)
    Thanks again to you guys.
    This Forum is great !
    Léonard de Vinci
  • 3dcad
    3dcad Member, OS Professional, Mentor Posts: 2,482 PRO
    edited April 2018
    The easy answer would be no, it's not possible to set limits using variables.
    But as you can control variable values using feature script where you can set conditions according to user input I would say this is possible to achieve with Onshape.
    Edit: As it appears you can do this also without fs.
  • bruce_williams
    bruce_williams Member, Developers Posts: 842 EDU
    Here is good post on expressions (including conditionals) by @lougallo
    And another thread on expressions
    www.accuratepattern.com
  • francois_boulet
    Thank you guys !
    Now I can say:
    Léonard de Vinci
  • billy2
    billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,194 PRO
    Configurations allow for variable input range.
    Take that variable and define it in a configuration.
  • remi_gendron
    remi_gendron Member Posts: 2
    So since no one actually answered this simply enough, I will.
    So FFR:
    There is a max(x, y) and min(x, y) conditional you can use.
    BUT THESE DO THE OPPOSITE OF WHAT YOU THINK
    max(6, 8) will return 8 as it is the bigger number.
    min(2, 4) will return 2 as it is the smaller number.
    The order of the numbers don't matter.
  • james_aguilar160
    james_aguilar160 Member Posts: 59 ✭✭
    To be fair, that's exactly what those functions do in every other programming language in existence. max returns the maximum value among its arguments, and min returns the minimum value.
