Custom beams feature
leo_timmermansleo_timmermans Member Posts: 8
Hello,
I'm trying to make some custom beams and this went quite well, but now I'm trying to make a custom beam for a roofplate. I followed the same procedure but it doesn't work. When I use the sketch and do a sweep, it works ok. I don't know what I'm doing wrong ??? Is it too big ?
Document
https://cad.onshape.com/documents/2eaac7afebe483107185ca4f/w/ac6d68c84d8b5a1216b331d2/e/44fd9cfb6d63c3b36229bedb
Tkx for your help
Leo
    edited April 2018
    Hi @leo_timmermans !
    A couple things:
    The link you posted doesn't really have anything in it! Did you edit it after posting this? A good rule of thumb is to paste a link to a version of a document, rather than the live document, so that you know whoever is opening it will see exactly what you want them to see.  Did you add a custom beam profile? If so, what is it's name?
    If you're having trouble with custom beam profiles, maybe @NeilCooke or the end of this video can help:
    https://www.onshape.com/videos/creating-weldments-06-13-16
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,436
    Thanks Neil!
    OK, it works now, my mistake, had to make another entry in my beams profiles. Completely happy now :smiley:
    Tkx for the help !
    Best wishes,
    Leo
