Rules for using wiring FS
nir_gurarye
Member Posts: 2 PRO
Hi, I have been using this FS to generate wiring and cables
: https://cad.onshape.com/documents/6dff8f67e2ef0b33193a10d2/w/ad1dd98bb99d14ca27c2eb74/e/0904f1281fabe33fcdd58945
however find it to be very temperamental. Depending on the radii I choose for the wire the 3D feature often does not generate properly. I am trying to figure out the guidelines of how to construct the 3D sketch so that the wire will generate properly. Can anyone advise?
jon_sorrells
Onshape Employees Posts: 52
If the bends in the wire are sharper than the radius of the wire, then it won't be able to create the wire. If you're having problems near the start or end of the wire, you can try adjusting the 'Starting straightness' or 'Ending straightness' or the wire.
In general, a smaller radius wire is more likely to succeed.
6
It is a bit tricky at first, but once you get the hang of it it's pretty easy.
https://cad.onshape.com/documents/be0dc32a1e39388ad7be37f0/v/f20b8008c602a72d618f305b/e/5d77ce5aaabb7360815450d0
