'Move To' not listed
Brian_McVeighBrian_McVeigh Member Posts: 78 PRO
When I right click on some Documents in My Onshape, I do not get the 'Move To' option to move these into folders - anyone know why this might be?
Cheers,
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,895
    If the doc has been shared with you, you may not have permissions to move it
  • Brian_McVeighBrian_McVeigh Member Posts: 78 PRO
    Hi Neil,
    The Document was created by me.
  • kevin_guokevin_guo Onshape Employees Posts: 18
    Brian,
    'Remove me from share' in the context menu typically indicate that the selected document is shared with you. Can you please open a support ticket and our support team can help you on this.
    Thanks,
    However, documents are by default owned by your company, so check that the folder is also owned by the company.
