Curious - How Many Users Use OnShape for 3D Printing Design?
in General
I use OnShape to 3D design and print exclusively but understand OnShape's market might not include that many who do. Was wondering how small a minority I might be in.
Thanks in advance.
Thanks in advance.
No problem, always happy to talk about such things, usually getting me to stop is the problem.
I've had zero problems with OS's stl generation and have done hundreds of them, coudn't be happier there.
As for scaling, I think you're on the right track with the printer slicer / material being the issue. For example printing a pocket for a bearing in a part that is 0.2mm oversize creates a nice easy press fit on my Tiertime machines. My Markforged gets a little closer. It's only ever of that order though. I printed a PCB test jig (many sprung test probes on icle test pads) and it all works great, no more CNC for that!
I've found designing parts specifically for printing becomes second nature after a while, be it optomised for strength, minimal support media, speed etc.
Cheers,
They usually learn Tinkercad first and that still has its uses in modifying or laying out STLs (exported from Onshape) before printing.
When designing a multi part 3D print project using a common sketch the STL output from Onshape necessarily has zero tolerance between adjacent parts. It is of course possible to adjust this either in Onshape or in 3D slicing software and I'd be interested to know how other users deal with this within Onshape? Do you sketch showing tolerances before extruding, rotating etc.or maybe utilise the Thicken tool or have I missed, as usual, another subtlety already available in Onshape? Please note this is a query about Onshape specifically, I'm not looking for a slicing tutorial. Thanks.
A couple other things for handling multiple parts -
1) Boolean subtract is pretty cool - you can offset faces of tools to the target. So that is a good way to get clearances if needed.
2) When exporting a part & assembly studio the option 'Export unique parts as individual files'.
Thank you both for your answers. I was already comfortable with the methods for exporting STL files, both single and multi part, and have done it often but only where the multiple parts were rigidly attached to each other.Today I was planning a multi part project which would be too tight a fit to articulate properly unless the size of one part was reduced slightly. I was then musing about best practice within Onshape to introduce the required tolerance. I had tried the Thicken remove tool with some success but some shapes wouldn't play along hence my question. I think Bruce's suggestion of using Boolean subtract is well worth pursuing - so I'm now off now to a darkened room to experiment.
I often 3d print things, and use a similar workflow. Rather than creating a new part studio with a derived part, though, I'll create a version once I'm done with my actual design and call it "finalized" or something. Then I'll branch off that version and do my 3d print adjustments. When I actually send it to the printer, I'll create a version on the 3d printing branch to capture the state of the design at each of the print iterations. I find that this is useful because I often have to iterate on my print 2 or 3 times to get it right, and it's nice to capture these iterations as versions so I can always go back and look at how my physical parts looked on-screen.
Here's an example where I used this workflow (not as clean as I described, but captures the basic idea):
https://cad.onshape.com/documents/ec4d9c75a4f6b2b6741f2799/w/790919b65a6679b9e59ec03e/e/2a1630ebfa945ac5703a4289
You'll see that "Full size" was my final iteration of the design itself. Then I iterated and created more versions as I tried different approaches for printing. I eventually had to try a couple different things to get a good fit between the handle and the blade using different materials in the printer, so I branched onto medium and low clearance approaches. I also had to make some changes when I got the blade printed in metal, which ended up on the "metal printing" branch.
Fundamentals 10 and 11 cover branching and merging:
https://learn.onshape.com/collections/onshape-fundamentals-data-management
Also helpful:
https://www.onshape.com/cad-blog/creating-versions-in-onshape
https://www.onshape.com/cad-blog/tech-tip-branching-designs
Thanks, that's a good method as well. A little bit cleaner than cluttering up the workspace with extra tabs.
Thank you for your thoughts. I think I now have a workflow planned.
Last SW chute: see how the bolt gradually walks the slot length
Last Onshape chute: slot is basically invisible now as it isn't needed as much
That is most gratifying to see. In Onshape did you use sketch pattern and cut in flat or curve pattern?
Also I am delighted to hear about the tighter geometry you are getting with Onshape sheetmetal! Nice job @Lana and our sheetmetal team!
