exercise wheel rim trouble ?
On the exercise wheel rim slide # 11 I cannot finish the fillet step due to a red line when I add the "extrude face 3"
I'm new to on shape can anyone help me with this
Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646
@cameron_shaw_doran
Please post the URL of your document here, many people will be happy to take a look for youJake Rosenfeld - Modeling Team1
The issue is with "Mirror 1". As shown on Slide 10, the "Features to mirror" should be both "Extrude 3" and "Draft 1" rather than just "Extrude 3". The "Mirror plane" should be the back face of the spoke, rather than the front face. With these two adjustments, the fillet works for me:
https://cad.onshape.com/documents/d8b5ebbe94e710d3360ad744/w/23266065e04424158c1b092a/e/1bf2459c9a9e5ab9033fcf77
Let me know if this doesn't clear things up!
I re-did the mirror 1 exactly the same as yours but it's still having an issue not sure why
can you help?
It looks like you fixed the first problem I mentioned but not the second problem. Your "Mirror plane" is using the front face of the spoke, but it should be using the back face.
