Could I get a part. Input by step file.
dragon_chen_dragondragon_chen_dragon Member Posts: 22 ✭✭
    @dragon_chen_dragon - Thank you for your post.
    If the Step (or any) file contains the definitions of multiple parts (as in this example), then post-import there will be individual parts in the Part Studio.
    If the imported file contains surfaces, or errors that make it impossible for Onshape to sew the faces of a part back together to form a closed volume, then those surfaces will likewise be listed in the Part Studio.
    There is a tech briefing in the learning center that covers these topics in more detail - https://learn.onshape.com/courses/importing-data
    Philip Thomas - Onshape
  • dragon_chen_dragondragon_chen_dragon Member Posts: 22 ✭✭
    Is it the same function? onshape
