Probleme on a Specific Mates
patrick_farley
Member Posts: 37 ✭✭
Hi, i have trouble making a specific Mates.
i got to tube 90 inch long that will be fix later on with side plate. So i don't have to have the pipe exactly cut the the perfect length
i can't find a way to fixe the second pipe.
i got a ball mate at the far end joinning the two pipe together but as soon that i try to add a second mate, everything failed.
Thanks
hope i am clear enough
Patrick Farley
Thanks
Patrick Farley
patrick_farley
Member Posts: 37 ✭✭
Ok i finally nailed it
i had to create a fake piece and make a sketch from one face of it.
it works.
Thanks for your help
Pat Farley
Can you share a link to the document so the forum users can inspect the situation? It's difficult to understand the exact problem without seeing the full picture.
i cannot "fix them" with group as they are not where i want them yet, i need to align them to have a perfect match before.
i don't know how to align part other then using mate.
i need the pole to be align to the top of the square tube.
i also need it to be align left and right, but there is no point that touch both part.
my part are like a triangle. right now i have 2 out of the 3 corner that are mate. but the third one does not touch each other and this is what i want, but align
EDIT: Sorry the fix in my first comment was refering to putting two metal plate on the side of each tube and rivet them
Thanks for your suggestion and help.
here is a link to my part
https://cad.onshape.com/documents/2ad8d2ddf9b883a4a22141b7/w/f2b8c3a6aaf6f1666d1c7165/e/0cd12af6eaed4c23ff434f9b
You are right about no moving part. So i can indeed put them in one part studio.
I don't have to do mate anymore.
But now i still have an issue, how to draw the third part in an angle in relation of the other.
i will try to make a plane from the end of my other pipe, but it need to be in an angle.
i will search to try to find how to do this, and close this question as soon as i have found a way
Thanks for your help.
it works.
Pat Farley
you could also make a plane (line angle) to sketch on
