Improvements To Onshape - April 13th, 2018
bradley_sauln
Moderator, Onshape Employees, Developers Posts: 373
This week not only has the arrival of warm weather in the Northeast but also, another Onshape update. Check out all the awesome new features that were added with this most recent update! Let's dig in!
EDITING LINKED DOCUMENTS IN-CONTEXT
Onshape Assemblies now support the ability to edit and create in-context geometry across linked documents. When returning to your top-level assembly from another document, Onshape gives you the option to automatically version the linked document and update the parent document to reflect those changes.
CONFIGURE SKETCH TEXT
With this update, we've added the ability to configure sketch text.
SHEET FLYOUT PANEL AND TAB
EDIT: This has temporarily been disabled due to performance issues.
In Drawings, we've redesigned the sheets flyout panel behavior to give you a better overview of the contents of views and their references. You can find the icon to open flyout panel on the left side of the screen, similar to our configuration, simultaneous BOM, and sheet metal panels. This change gives us a better foundation for future work.
ADJUSTING CONFIGURATION NAME COLUMN WIDTH
In the configuration panel you will now be able to adjust the width of the Name column to remove extra whitespace in your tables. This keeps the panel size to a minimum.RELEASE MANAGEMENT FOR USERS THAT BELONG TO MULTIPLE COMPANIES
If you're part of multiple Onshape companies you will now find that a document's release management workflow will adhere to the release settings of the company that owns the document.
Do you have a great idea for a new feature or improvement in Onshape? Please post your ideas in the Onshape Forums or vote on existing feature requests to help us prioritize development.
O.S.
Thanks!
Have you checked out the Learning center?
We provide a lot of material to help out users there. https://learn.onshape.com
We also have help documentation. https://cad.onshape.com/help/
If you have any questions, our forum is a very friendly and helpful place to post questions. You will probably get a GIF or a document showing your answer within a couple hours.
I too would like to examine longer videos of complete projects where Onshape explains the workflow considering standard parts (subassemblies), configurations, in context stuff, performance, drawings, BOMs, sharing, addins like render / FEA etc.. you know the whole thing that we deal everyday.
It's so easy to create & edit something that doesn't belong to anything.
But first things first, assembly configurations, please
If so, let us know what other information you would like to have available to you to understand how to take full advantage of the versioning/branching/linking/in context.
A video walking through a project is a good suggestion @3dcad.
Twitter: @bradleysauln
I personally have been pouring over every video and tutorial I can find. I am getting a better understanding of versioning and branching but in context has me stumped for now. I am self teaching with very simple parts and assemblies and just when I think I understand, an issue arises and I'm back to google and videos for an hour to try and understand where I went wrong. I currently have an in context part that finds itself off the origin so I can't mirror efficiently and I don't intend to make this thread about that particular problem but it's that kind of issue that I'm currently in to for over an hour trying to find a reference or solution before posting here asking for help - again.
The help here is second to none but the depth of understanding that the helping individuals have sometimes works against newer users as there are so many skills that are assumed to be possessed by those in need of help that it becomes very much like a foreign language. Learning that new language takes time and I am learning there are no short cuts.
For your specific problem, if sounds like the Plane feature may help you set up a mirror plane where you need it:
https://cad.onshape.com/help/Content/cplane.htm
Since you are a pro customer, you have access to our in-context learning center course:
https://learn.onshape.com/courses/managed-in-context-design
This may help solidify your understanding of our approach to in-context design.
Keep in mind, the hotkey Ctrl-S can be used to quickly toggle this flyout open and closed.
It's true if I return to a drawing I have visited before in the current session, there's no flyout. But, if I move to a new drawing or if I close the session and return to the same drawing upon re-opening, it does flyout. I think most would prefer that it never flyout unless the tab is clicked.
Ok, let's think - with trad.cad we would either install old version back and search backups for files that work with old version and figure out what changes we lost or wait 1-6 months for hotfix or service pack and cope with broken feature until then.
Now we lost part of new functionality to avoid issues but got old functionality back. So we have still have better cad than 'old version', all documents are working and no work got lost. And we didn't need to do anything.
You still have my trust Onshape team, thanks for being honest and acting when issues appeared.
