Section view of only specific parts in an assembly
Gage
Member Posts: 5 ✭✭✭
Is it possible to create a section view of only some parts in an assembly? For instance, how the cutaway view below cuts through the engine block but not the pistons, valves, crankshaft, etc.
Thanks you
Thanks you
This functionality is not available. Can you submit an improvement request? Thank you.
Since our features can affect multiple parts simultaneously you can make the cut in just the parts you want.
Twitter: @bradleysauln
1: Part studios generally do not contain the parts in the same quantities, location, orientation, etc. as the assembly, therefore a lot of work could be required to use your suggested method to achieved the desired result. You'd very likely need to create multiple cuts in multiple different part studios, and this would be impossible to achieve with recurring items which could be cut differently by the desired assembly section plane.
2: This has the potential to take an extremely long time, probably never being worth the effort.
Has an improvement ticket been submitted for this basic functionality mentioned almost a year ago? If not I will create one now.
I'd use the new at assy as the transform will kill all the nice instancing the original assembly had.
For this specific case then perhaps squirt just the sectioned engine block parts back to the original assembly, then show or hide either the full or sectioned parts.
Assembly configurations would be awesome here.
Owen S
