Split surface into separate surfaces
Hi,
I've tried to split a sphere surface (hollow, not a solid part) into 2 domes. The split is successful with the split line showing, but the surface is still taken as just a single surface.
This is in contrast with splitting a sphere part (solid). After the split, the original part is separated into 2 parts.
I've done both splits in the document below. The Blue ball is the surface and the Grey ball is the part:
https://cad.onshape.com/documents/5d621b0c356996979d9a28fb/w/4f81c537364abbeeac24cf78/e/02b067aad1a6b2ad02ded393
Why is it not possible to split the sphere surface?
michał_1 Member, Developers Posts: 215 ✭✭✭
In both cases, you should use split part, not the split face option.
5
projektowanieproduktow.wordpress.com
michał_1! Yes, if I choose to split part instead I'm able to split my surface now.
Just that with split face, I could split the sphere with just 1 diameter line as entity, so it was more convenient than having to define a plane for the split entity. However, that was only able to split the face and not the surface, so can't use that for my case.
