Revolute Mate (Probably very simple)
steven_phangsteven_phang Member Posts: 5
Hi, I'm new to all of this...
Im trying to make a box with a rotating hindged lid on top with two parts: the box and the lid
I tried to put a revolute mate on it to see how it opened and it worked, but it rotates a full 360 degrees where the top of the lid will phase through the box. I wanted to test if the lid had enough clearence to swing open, but I can't if it just goes through the box anyway.
Is there a way to make it so it stops rotating if the top of the lid hits the box so it does not go through?
I appreciate any help I can get.
Thanks!
  • MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,056 ✭✭✭✭✭
    It is no easy, and it is no very clean and fast... but it works
    @steven_phang
    @emagdalenaC2C
    Try doing a section view in the assembly
    It will show overlaps in red
