Revolute Mate (Probably very simple)
Hi, I'm new to all of this...
Im trying to make a box with a rotating hindged lid on top with two parts: the box and the lid
I tried to put a revolute mate on it to see how it opened and it worked, but it rotates a full 360 degrees where the top of the lid will phase through the box. I wanted to test if the lid had enough clearence to swing open, but I can't if it just goes through the box anyway.
Is there a way to make it so it stops rotating if the top of the lid hits the box so it does not go through?
I appreciate any help I can get.
Thanks!
Thanks!
emagdalenaC2i Member, Developers, Channel partner Posts: 863 ✭✭✭✭✭
Ok, let's take an example like this one:
https://cad.onshape.com/documents/e4743eb6578279537d5858f3/w/3338eb3f83d325dbe4a85ef8/e/64816f8997d2529609467250
1- You can create a few named positions in the assembly
You can edit the limits of the revolute mate to create easily that named positions
2- Edit in context one of the parts (the fix or grouped one)
3- Transform and copy in place the other part (The part that can rotate) at a specific angle defined in a named positions
4- You can use a FeatureScript like "Find overlaps v2" included in this example to get the overlaps between the 2 parts at that specific angle
Now you can test if there are overlaps with another angle (other named position)
1- Change the angle (select other named position) in the assembly
2- Go to the Part Studio and update the context
3- Then you can check if the parts overlaps
It is no easy, and it is no very clean and fast... but it worksUn saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común6 -
MBartlett21 Member, OS Professional, Developers Posts: 2,056 ✭✭✭✭✭
emagdalenaC2C said:It is no easy, and it is no very clean and fast... but it works
@emagdalenaC2C
Try doing a section view in the assembly
It will show overlaps in red1
@emagdalenaC2C
