Performance Issue on Monitor
Ethan_Rejto
Member Posts: 4 ✭
in General
Today I got a new monitor. Dell UltraSharp 27 Monitor. I noticed significantly worse performance when running Onshape on the monitor vs. on my PC screen. I have display pixel matching off in my preferences.
Test Results from Monitor.
Test Results from PC:
You could try your tests in Firefox to see if you get similar results. If the results are consistent there, I would suggest filing an issue so we can investigate further. (Look for "File a bug" or "Feedback" under the ? dropdown)
-- Does your laptop have an Nvidia Optimus GPU (dedicated GPU)?
-- What resolution are you running the Dell display at vs the Inbuilt screen?
-- When you performance is worse - are you just referring to the Performance Check or actual Onshape modeling?
