How do i draw a line between two planes
peter_roberts941
Member Posts: 14 ✭
in Drawings
I am trying to recreate the shape in the picture.
I have drawn the initial patern, extruded then created a plane on the extruded face and a second time to generate the full depth shape.
The problem is that i cannot draw across from pne plane to another. I envisage makeing a few different patterns using the same concept.
Help please?
Thanks
Help please?
Thanks
1
https://cad.onshape.com/documents/b04fbe8f147253e5697006a9/w/723e3da5ffc10de47d0e92d2/e/4317cdbd3237333550c317fe
I am trying to recreate the individual panels within the picture. They are 3D. I am wanting to make a mould or patern for this.
Thanks
If you sketch the endpoints of the two lines on their respective planes, you can use 3d fit spline or bridging curve tools to make a line between the two endpoints (thanks @mbartlett21 for mentioning this):
https://cad.onshape.com/help/Content/3d_fit_spline.htm
https://cad.onshape.com/help/Content/bridgingcurve.htm
Fit spline is probably a better tool for this job, but both tools are powerful in their own way.
https://cad.onshape.com/documents/4d6a4ad1dcce9c44cf5fe994/w/c0275fbe06c215e32a30e451/e/82ae60ada16debf4c722a02f
