Can't extrude spline problem
steven_phang
Member Posts: 5 ✭
Hi! I traced an image with the spline tool and with the line tool, but I can't seem to be able to extrude it. Any help/advice is appreciated... I am a beginner. Attatched is a picture of what I am trying to extrude and a link to a copy of the project.
https://cad.onshape.com/documents/d46396a030c81a22adc1cfa3/w/0bedb8047d422e7c1e85ead3/e/b6aae1169b159e7414d5632b
brucebartlett
Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
I tried and could not extrude any region from your sketch, not sure why.
To get it to work, instead of working on a massive sketch with lots of regions, try breaking it down in few sketches with a smaller number of regions ideally with no crossovers or common edges. You could use the use feature from the current sketch in other sketches that worked for me just now.5 -
emagdalenaC2i
Member, Developers, Channel partner Posts: 864 ✭✭✭✭✭
There are a few issues in your sketch. You should create several sketches as simple as you can.
You could create new sketches based on the existing one and Use (Project/Convert) small areas of your sketch.
You can use the Create selection tool to do it easier
https://cad.onshape.com/documents/2c1bc4a237b7a16ce250395e/w/97d446b7915d0216e802fa8c/e/2428bb8516d7a24f8baf0732
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común7
