How to draw on a plane that's diagonal to existing part?
in Drawings
Hello. I'm just learning OnShape and could use a nudge in the right direction. I've made and printed some mostly simplistic 3D parts with OnShape, but I'm stuck on a concept that I need for a part cooling fan chute. I designed a carraige fan mount and now need to direct the air from the fan's output to near the extruder tip. I need for the chute to be angled inwards at some angle, towards the tip, but also backwards a little to center the tapering chute relative to the tip.
Imagine two rectangles end-to-end on one plane. Now rotate one of them upwards at, say 45 degrees. Next, skew it perpendicularly by some degrees. I've been unable to figure this out, or even know how to seek instructions on it.
Thank you for any tips.
Maybe you need to add a new plane angled off an existing plane or face to sketch on. If modifying existing geometry "move face" by rotation could help, also, "loft" may help to create the geo you describe.
Thanks!
https://cad.onshape.com/documents/02e9a685ad869ca4c4161c42/w/c56c3a61e789fbddd5e60310/e/197ee20e28b72d8ef7f9c032
https://cad.onshape.com/documents/f91a2cc915f225f0d70b7bf6/w/46407ee99f42412bb604b04e/e/14f05d81686750d14e566f85
As I look more closely it doesn't seem like the top piece would be usable with that twist. Maybe try a loft/twist lower on the part?
https://cad.onshape.com/documents/f91a2cc915f225f0d70b7bf6/w/46407ee99f42412bb604b04e/e/d1f4cbc6d729db7c6ad15997
