Can't create thread, Just get an error and red thread outline
sean_parkinson
Member Posts: 3 EDU
I've been struggling for about an hour, searching the internet and what not to see if anyone else was getting this issue, I was originally trying to create a thread for a Hydraulic cylinder, but I made screw just to make sure I could get the issue to appear again. I know its most likely because I'm just missing it, but I'm very new to onshape.
Thanks.
Thanks.
Bruce meant to post this link:
https://forum.onshape.com/discussion/9107/forum-post-checklist#latest
It's very hard to start debugging your issue without first seeing the document itself.
posted from I-pad and messed it up.
@sean_parkinson
Sorry about that. Hope you worked it out or share the document as public and you will get lots of folks helping out.
https://www.youtube.com/watch?v=HUMhT9LGQ7U
https://www.youtube.com/watch?v=OAuh_gQofJA
https://www.youtube.com/watch?v=zImdPKVW8wY
Are you sure you're cut triangle is intersecting the part you are cutting?
Did you make sure you selected a merge scope?
