Can't create thread, Just get an error and red thread outline
sean_parkinson
Member Posts: 3 EDU
I've been struggling for about an hour, searching the internet and what not to see if anyone else was getting this issue, I was originally trying to create a thread for a Hydraulic cylinder, but I made screw just to make sure I could get the issue to appear again. I know its most likely because I'm just missing it, but I'm very new to onshape.
Thanks.
Thanks.
Please see the post here for guide on how to share a link and someone will help. https://forum.onshape.com/discussion/9107/forum-post-checklist#latestwww.accuratepattern.com-1
The link you just posted links back to this post.bruce_williams said:Please see the post here for guide on how to share a link and someone will help. https://forum.onshape.com/discussion/9219/cant-create-thread-just-get-an-error-and-red-thread-outline
@sean_parkinson
Bruce meant to post this link:
It's very hard to start debugging your issue without first seeing the document itself.Jake Rosenfeld - Modeling Team0 -
Thanks @Jake_Rosenfeld
posted from I-pad and messed it up.
@sean_parkinson
Sorry about that. Hope you worked it out or share the document as public and you will get lots of folks helping out.www.accuratepattern.com1 -
Have you seen these videos?
https://www.youtube.com/watch?v=HUMhT9LGQ7U
https://www.youtube.com/watch?v=OAuh_gQofJA
https://www.youtube.com/watch?v=zImdPKVW8wY
Are you sure you're cut triangle is intersecting the part you are cutting?
Did you make sure you selected a merge scope?
1
