Improvements to Onshape - May 4th, 2018
cody_armstrong
cody_armstrong Posts: 228 image
edited May 2018 in New in Onshape
It's May already and we're here again with an exciting new update for you. We have a lot to cover, so let's dive in.
ASSEMBLY LINEAR PATTERN IN MULTIPLE DIRECTIONS
You can now create Assembly Linear Patterns in multiple directions in a single command.
https://youtu.be/i9AwnnNM8Z8
PART NUMBER GENERATOR IMPROVEMENTS
Onshape Professional users can now generate part numbers in the workspace properties dialog as well as in the Simultaneous Bill of Materials flyout. In the past, the ability to automatically generate part numbers was limited to the Release Candidate creation process.
https://youtu.be/8noQViRlA8I
KEYBOARD SHORTCUT FOR SWITCHING BETWEEN RECENTLY OPENED TABS
There is a new keyboard shortcut for switching between recently opened tabs. Press ctrl + spacebar to view recently opened tabs, then press the spacebar again to cycle between the tabs. Let go of the ctrl key to open that tab.
https://youtu.be/Rbdk1GI3I3o
PROPERTY DISPLAY NAME
You will find a new option for "Display Name" when editing your company's properties. This allows you to change the way the property is displayed. For example, changing "Quantity" to be displayed as "QTY."
https://youtu.be/iNXxgqY-mK8
GO TO ITEM IN LIST
If you right-click a part or subassembly that belongs to a nested subassembly, you will see a new option to "Go to item in list." This will expand out the subassembly and highlight your selection in the instance list.
CONFIGURATION NAME IN ASSEMBLY TOOLTIP
A tooltip with configuration details now appears when hovering over parts in the assembly instance list.
DRAWING WATERMARKS
As a company owner or admin, you will find a new option under the Release Management settings to "Show watermark for unreleased drawings." This automatically adds a watermark to all drawings except drawings that are released.
https://youtu.be/1NpyrQSlSFI
NOTES WITH MULTIPLE LEADERS
Notes in Onshape Drawings can now have multiple leaders. Simply right-click a Note with a leader and choose the option to "Add leader."
https://youtu.be/ka9-jaMhpMg
INSERT SURFACES INTO DRAWINGS
You can now insert surfaces into Drawings in Onshape. Surfaces will now appear as an option when inserting and you have a new filter in the insert dialog to make inserting only surfaces easy.
https://youtu.be/1rRiSIyh19s
ADDITIONAL NOTE FORMATTING OPTIONS
You now have the option to insert numbered and bulleted lists in Notes in Onshape Drawings. There are also new options for specifying upper and lower case letters.
VIEW FEATURE DIALOGS WHEN SHARED WITH VIEW AND COPY PERMISSIONS
If a Document has been shared with you with view and copy permissions, you can now double-click a feature in the feature list and see the details of that feature. This can be helpful for many reasons. One example is now it is possible to review the features and steps of a public Document without creating a copy first. This also means it is now possible to see the parameters of a feature in a version. In the past, you would need to create a branch to do this.
Please take a moment to try out these new features and improvements and leave your comments below. For a detailed list of all the changes in this update, please see the Onshape Changelog.
«1
  • RyanAvery
    RyanAvery Posts: 93 EDU
    update lukes good.
  • owen_sparks
    owen_sparks Posts: 2,660 PRO
    Nice work folks, thanks for the relentless updates.
  • robert_morris
    robert_morris Posts: 176 PRO
    Great set of updates, thanks everyone!
  • 3dcad
    3dcad Posts: 2,482 PRO
    Very useful new features, thanks! :+1:
  • brucebartlett
    brucebartlett Posts: 2,148 PRO
    Great to wake up to a new release. Lot's of little things needed to make work easier.  Go to item in list is going to save me heaps of time clicking to expand subassemblies. Thanks!
  • john_mcclary
    john_mcclary Posts: 4,095 PRO
    View feature will make checking users documents on forums much easier!
    So many good updates this week, good work!
  • brucebartlett
    This is a good improvement, I was just checking back over an old version yesterday and couldn't get the details I wanted, now I will be able to.
  • john_mcclary
    It's transparent to everyone but the forum watchers. But its nice to see even that level of comitmit from the devs
  • emagdalenaC2i
    emagdalenaC2i Posts: 867 ✭✭✭✭✭
    edited May 2018
    Nice improvements as always!!
    PS: It seems that it is raining  ;)
    Un saludo,
  • bruce_williams
    bruce_williams Posts: 842 EDU
    view features should cut down on copies and will be very handy for checking parameters in versions.  Nice!  thanks
    www.accuratepattern.com
  • MBartlett21
    MBartlett21 Posts: 2,064 ✭✭✭✭✭
    This is really useful. Thanks.
  • Michael_V_Hasson
    Michael_V_Hasson Posts: 1 PRO
    Multiple leaders!  Ahhh... it's the simple things in life that please us most  ;)
  • emagdalenaC2i
    I do not know why but sometimes when I play the videos I hear the audio but the images are not displayed.
    It never happened before,
    Has it happened to someone else?
    Un saludo,
  • brian_jordan
    brian_jordan Posts: 144 ✭✭✭
    I do not know why but sometimes when I play the videos I hear the audio but the images are not displayed...
    I see exactly the same here also if I try to view the videos full screen the top left is obscured by a fixed picture as in the attached screenshot.
    Windows 10 Pro Spring 2018
    Google Chrome is up to date
    Version 66.0.3359.139 (Official Build) (64-bit)
  • emagdalenaC2i
    Seems There is a new missing improvement ;-)
    Thanks to @john_hackington for pointing it
    In the arrays feature (linear, circular and curve) if you select the Feature pattern option you will see a new checkbox "Apply per instance"
    If you check the Apply per instance option all the instances are recalculate
    And if it is unchecked it just copy the geometry
    Here is the link to this document https://cad.onshape.com/documents/82b4f8320598247dfa2b9fea/w/e5613c929a82bb3271d7602e/e/385335c3237f50589d0218b0
    Un saludo,
  • brucebartlett
    You can always check the changelog for a full list here https://www.onshape.com/changelog
  • emagdalenaC2i
    edited May 2018
    I mean missing because there is not in the changelog  ;)
    My fault... There is
    Un saludo,
  • emagdalenaC2i
    and I'm glad that by default this option is disabled
    SolidWorks still keeps it enabled by default and in most cases is not necessary
    Un saludo,
  • bryan_lagrange
    bryan_lagrange Posts: 1,036 ✭✭✭✭✭
    Good update. Fingers crossed for more sheetmetal updates in 3 weeks.
    Bryan Lagrange
    Twitter: @BryanLAGdesign
  • brucebartlett
    Does the multileader work on Balloons as well?
    I think the answer is no, as I couldn't get it to work but thought I'd ask in case I'd missed something.
  • MBartlett21
    @emagdalenaC2C
    Try refreshing the page
  • emagdalenaC2i
    Yes, refreshing the page sometimes works... and sometimes it doesn't
    Un saludo,
  • jakeramsley
    jakeramsley Posts: 669 image
    Multi-leader is currently for notes only.  We have additional work to get them to work properly for other things like symbols, dimensions, and callouts.
    Jake Ramsley
  • Yes, refreshing the page sometimes works... and sometimes it doesn't
    We are looking into this.
  • EricGauthier
    EricGauthier Posts: 73 ✭✭✭
    Great improvements again! (-:
  • Andrew_Enslow_3DS
    Andrew_Enslow_3DS Posts: 40 ✭✭✭
    Thanks for all the improvements. I'm enjoying the development of the Data Management.
    Special thanks for...
    • Multiple leaders in drawings
    • Viewing configuration details with a hover
    • Assembly Pattern
    • Drawing Watermarks (These are cool!)
    • Go to item in list
    • Quick toggle between tabs (CTR + space)
    • List options in drawings
  • emagdalenaC2i
    Un saludo,
  • AuroraRon
    AuroraRon Posts: 141 PRO
    Love the new features.  Keeps getting better all the time.  Keep up the great work.
    Wish Onshape spent some time on the mobile / IOS side of things. Feels like it has been abandoned.  No real change in the past year.
    Others are now offering the ability to import, export and forward on files and drawings. Really basic stuff.
