How can I project a square hole in a curved sheet metal part.
https://cad.onshape.com/documents/0f17179a7aabee3982fd5d48/w/a35280ab15fed51ddfa1a908/e/8a15d772748a0af7c15e5b9c
I've struggled with this now for a couple hours and I think the answer is "It's not possible". I have a segmented sheet metal elbow as is commonplace in my fabrication world. I have a square take off on the heel of this elbow. How can I project my square hole through the elbow segments?
lana Onshape Employees Posts: 728
Sorry, it took me some time to get to this issue. It is a bug. In fact, this model exposed several issues. Thank you for bringing it up.5
https://cad.onshape.com/documents/e7a1fc52315363260181e6e0/w/027b5afe1b08d6dc5da08875/e/2ad7b2f78ef4fb55683db0ff
As a workaround, I thought maybe try creating these as single segments, but same problem here too. @lana any idea's on this one? Is this a bug?
Again, thanks for your help.
Kent
If you find Onshape sheet metal functionality lucking, please file (or vote up existing) improvement requests.
@lana thanks for looking into the problems Kent found and we look forward to some good solutions. This one is a great test case for Onshape. I am thinking one improvement that would help is to be able to export all the flat patterns to different dxf files in one go out of the flat view. At the moment they have to be individually selected and exported 1 by 1. I'd be keen to hear other thoughts on this too.
That is a great suggestion. Thank you.
Twitter: @BryanLAGdesign
Here's an Onshape pet peeve. When I export flat patterns to .dxfs the creation of the .dxf tab within Onshape isn't helpful at all. I really just want it exported to use it somewhere else, right? Going back and deleting each .dxf created within Onshape is a bit of a pain. I'm not sure why they're even created.
There should be an option for this in the export dialog:
If you set the option to "Download", a new tab will not be created in your Onshape document.
Please let us know if you do not see this option, or if it does not work in the way you expect.
My dream would be for a cloud integrated CAM App for Onshape would be created for laser/plasma/water jet with nesting functionality. If there is a developer needing more info I can supply sample posts for Trumpf lasers, Flow Water jet, and Messer Plasma. I would also be willing to test them. Just throwing that out there.
Thank you for clarification. Sounds doable.
Without trying yet, I am interested to know which dxf's it exports? Is it all, from every sheet metal feature in the current part studio or just the ones related to the current flat veiw feature?
It is all flat patterns belonging to current sheet metal model (current view).
