Way to unwind rope from one spool to another?
chris_8chris_8 OS Professional Posts: 102 PRO
I'm pretty sure the answer is no, but I figured it was worth asking. People do some amazing things with Onshape
https://cad.onshape.com/documents/2f2a6c16d9881cf261c18e37/w/c1dfbcd3147fff60c372b2a5/e/796ba4fe86e35b4a01e01bbc
  • mahirmahir Member, Developers Posts: 1,314 ✭✭✭✭✭
    FS can definitely help do this and a lot of other useful things, but in this case I was just using conditional logic with variables. That alone doesn't require FS - just an understanding of variable expressions. In this case I was just using an alternate version of an IF statement (X?A:B translates to If X is true do A, if not then do B).
    edited May 2018
    I can't think of a way to do this as a smooth animation within OS, but I'm pretty sure you can link the height of helix2 to the height of helix 1 using in-context references. This would give you a similar effect as winding/unwinding both spools, but only when you updated the context. You could then create an animation by grabbing individual frames and stitching them together with a gif editor, but I don't think a live OS animation is possible. You can only animate mates/relations, not part rebuilds. If you model everything in one part studio it would be a little easier, but it still wouldn't animate smoothly. I'll take a look at it.
  • chris_8chris_8 OS Professional Posts: 102 PRO
    Wow, thanks for looking into this @mahir .   I've skirted away from FS coding so far because I never feel like I have time to learn it.  But now it seems I should start reading.   I appreciate your input!
    Chris
    Ah, ok,  I'm familiar with variables in general, but haven't used if/then statements yet.   When I finally finish my current pile of work I'll try it out
