I prefer ISOCPEUR. Reminds me on the early days, starting with technical drawings and using templates to draw on transparent paper with ink
Best regards
Martin
Dries
It's not just a question of whether we, the Onshape user, have a recent app which can use a recent version; sometimes the suppliers who do profile cutting do not, and that's beyond our control.
+1 for Arial on drawings (aka Helvetica on a Mac)
Must be getting close for the next update soon.
Engineering Consulting Partner
Professor, Engineering Technology, Palomar College, San Marcos, CA
sowelldevon@gmail.com
760 809 9046
CarlsbadCAD Carlsbad,CA
These do not by themselves serve any purpose in a solid model, in terms of creating solid protrusions or recesses, and it is traditionally difficult in most packages to manipulate and proces them to yield a realistic depiction of (say) an engraved line of text (using a V-pointed engraving tool). *
That's a "nice to have", but what is essential is a way of attaching (if necessary, wrapping) the geometry to a face
*One way to do it is to team up a single line font with a corresponding "rounded terminal" outline font, like VAG Rounded, originally designed (IIRC) for VW.
http://cdnimg.fonts.net/ImagingService.ashx?imagetype=thumbnail&shopid=47971&RenderText=The+quick+brown+fox+jumps+over+the+lazy+dog.+The+quick+brown+fox+jumps+over+the+lazy+dog.&TextSize=32&width=1000&TextColor=#000000&BgColor=#ffffff
The latter can then be extruded with draft, which (if the depth is specified overdeep) produces a sharp-bottomed V - at least in Solidworks. However it is necessary that outline text is able to split a face into multiple discrete areas for this to work. This used to be difficult in Solidworks.
https://cstools.asme.org/csconnect/CommitteePages.cfm?Committee=C64041150&Action=40068
Here's a link for single line Fonts, easy to machine. https://www.google.com/search?q=single+;line+Font&tbm=isch&tbo=u&source=univ&sa=X&ei=y9g3VZDgCYyfgwTSkICYAg&ved=0CCEQsAQ&biw=1920&bih=920
Also, really I'm not that picky about the Font used in 2D drawings. I would never spend any time changing the Font on an existing drawing unless someone else complained about it.
There used to be an issue in SolidWorks Drawings many years ago that 1:1 DXF drawings weren't actually 1:1, fixed these days.
Finally, I tell my SolidWorks students that 2D drawings is a misnomer; they're locked views of wireframe 3D models
760 809 9046
Also good move dropping the dxf export back to R11.
Amen with @BruceBartletton retrograding of dxf export: engraving machines see very light duty and last for decades, still run perfectly well on a 286 (!) era computer ... and compulsory/unhelpful/unavailable software/hardware upgrades, particularly when forced on cost-effective third party subcontractors, are Not Our Friend.
http://en.wikipedia.org/wiki/Engineering_drawing
They mention Gothic Sans-Serif, I'll attached a photo of that font.
Again, these days using CAD, I think it's a minor point, not like when I took my Final Exam in college using Ink on Vellum! (I cheated by making it first in AutoCAD, then I traced over it
760 809 9046
By contrast, Gothic Sans, mentioned by @Devon_Sowell , has 27 completely different variant families (not just styles, like bold or narrow) in the single link he posted, one of which may be the particularly offensive New Century Gothic, with insufficient heft, pointy terminals et al, chosen (perplexingly) by Solidworks.
Consistency is important, not least because nothing looks worse than a drawing where the text runs over borders or into parts, due to substitution of a font with different leading and kerning, not to mention basic width.
However going the single-width route, reverting to fonts intended for pen plotters, does not appeal to this kid. Drawings are more than just a means of communication, and if we don't care how ugly they are, we degrade our little corner of the world, just we would by entrusting the look of our place of business or residence to the lowest bidder.
except I don't think you actually intended proposing a logical proposition, more of an illustration of various criteria.
Let me ask this: Do you consider Arial to be lacking in authority?
( For those who might think earnest discussion of font style represents time wasted, I'd have to say that a study of the history of Apple Computer -- among others -- might suggest a rather different POV )
Arial is probably the best font that is most accessible that wasn't designed for engineering drawings.
I'm fairly certain fixed width fonts are required by ANSI Y14.5 which is more important than form. Drawings are legal documents and must meet Y14.5 specifications (or ISO whatever, DIN whatever, etc). Also, the Y14.5 font I linked earlier contains all the feature callout symbols required by Y14.5, which Arial does not have. Even if you used Arial you'd have to make use of these fixed width features and visually they won't match up!
Edit: The font I posted is not fixed width. Hmmmm. I guess I'll have to concede to not being sure about the font, except that the font I posted has feature callouts built in which is nice.
In other situations, it seems to me that consistent width (across platforms) is what matters.
Kudos for being fair-minded, @Onshaper.
As a reciprocal concession, there is the potential problem with ambiguity in many non technical fonts.
Arial does, however, seems better than many, and in my CAD-standards negotiator days across several large and exacting organisations, we found it relatively blameless, in practice, on this score.
The lower case l vs numeral 1 is quite well differentiated, as is the 0 vs O, and in any case, many people will occasionally misremember whether the strikethrough of the latter pertains to the numeral or the alpha instance (admittely that's mainly because technical fonts are so rarely used outside niche disciplines.) Wireless router passcodes are routinely misinterpreted in this way.
Wading into this discussion relating to Onshape's drawing capability and the fonts to be used on a drawing if I may.
The first thing I would say is that if a person (student) of mine was to had in a drawing done in a 2D package or off the back of a 3d model (ie Solidworks/Inventor etc.) and the notations used Arial as a font they would be marked down quite severely. Arial and other similar fonts are for commercial printing and newspapers NOT drawings. The reason being all the units of competency covering those tasks require adherence to AS1100. I'm sure that would go for other draughtpersons in other jurisdictions using other standards.
Therefore any professional CAD draughting should have as its basis fonts which conform to those standards. That's an easy answers to the question and not as hard, to comply with as it would seem. There is some latitude given and, even I am flexible in understanding CAD vendors are in no way (truthfully) interested in standards other than their own.
Dare I say it, but a look at Autodesk's AutoCAD & Draftsight for a method of implementing Fonts choice and flexibility in adjusting heights, spacing, width and angle of fonts/styles used.
This is, of course, leads into one of the great challenges of 2D CAD as a stand alone or as an adjunct to 3D; it needs to be as flexible as possible in all settings to allow the drafty to produce a document which conforms to the standards of the jurisdiction and or the company in which s/h/e is working for/in.
Given we now can works so easily across the globe we live in - (Onshape extends that capability) – flexibility (and its subsequent complexity) is all the more important to ensure compliance is not a stumbling block to winning a contract.
you have to look back into CAD history to see where and why many fonts originated.
I started my career at 11 working in my Dad's architect office doing drawings, by hand on a drawing board. AEC drawings tend to be very notation heavy, so when we used to do things by hand the style of the text was that scriptive architect style. For notation this was the best option, but for drawing title blocks and view titles we used Rotring pens with ISO lettering guide stencils.
As I moved on, still on the drawing board, to more engineering based jobs (IBM for one...still have their drafting manual from the early 80s) we moved from scriptive notation to full stencil notation. This was exceptionally tedious. But even back then for heavy annotations we used to type, yes on a typewriter, and stick the paper onto the drawing, then photocopy.
Then CAD came along. Finally we had the capability to add notes as desired! But the downside here was output. Back in the early 80s the output options were pen plotter or dot matrix. Dot matrix was totally unsuitable for drawings so we used pen plotters.
now we get onto fonts. There had to be a typeface that allowed single stroke plotting, hence most CAD systems of the era had limited plotting fonts based on the ISO stencils we used with pens. Then came the Mac and the laser printer.
I can vividly recall in 1987 seeing a report written by a fellow student at the RCA in London (Ted from Boston) who had used a Mac and a laser printer. "But its like a printed book" I said, astounded. "Well yeah, its done on a Mac" he said looking like Ihad stepped out from the Dark Ages. And that is what it felt like to me. I could produce work that looked like a book! Suddenly we had typefaces, crisp lines, shading! Witchcraft!
So moving on a few years to when I started my design business in 1990 I bought a Mac and a A4 laser printer. I used MiniCAD for drafting and basic 3D modelling. I could use any typeface available in my drawings so I used Helvetica. I was trained in the "classic" way in drafting but to me using those archaic fonts was keeping one foot in the past and refusing to move with the times.
moving on another few years we bought in SolidWorks and switched to Windows, so the default typeface became Arial (the MS equivalent of Helvetica). In 2003 I decided to purchase VX (now ZW3D). Back then it came as a terrible shock to me to see VX drawings could ONLY use line fonts! It was like stepping back 15 years. I campaigned for them to introduce Truetype fonts, which they eventually did.
Drawing is about communication. You use what best communicates the concept. Does a drawing that uses Arial or other standard fonts communicate the notation any less well than a single width line font? No. I would argue it is more readable.
All I ask from a drawing is that the typeface used is 'professional'. Comic Sans is a font designed for use in comics and early stage readers in school. Schools love it because it has 'proper' A's as you would teach handwriting. It is not a font for use on a drawing defining a mission critical assembly or component.
likewise with AEC. The number of architect drawings we see with Tekton as the font or another similar handwriting font is crazy. Architects love that font! Yet ask and AEC software developer and they all hate it because it creates merry hell with some systems. I used to train architects in use of 3D processes and my opening gambit was ' ditch the Tekton and use Arial' That usually created some interest from the get go!
so for Onshape, stick to what SolidWorks and the other do (and remember they have to operate in the confines of the browser eco system so some exotic line fonts might simply be impossible to do). For GD&T use symbols, like everybody else. For dimensions, titles and annotations use standard typefaces. For CAM and single path etching (I've used laser etching for 15 years...you can do standard typefaces!) add that to the CAM module or simply import a 2D profile onto the part (which is what we do in other systems).
Far more useful for me would be to be able to import an Adobe Illustrator path onto a part for bringing in Logos and special typefaces. DXF and DWG tend to segment up these things. But then maybe I'm too used to using things like SharkFX and Rhino where importing an .ai file brings in clean editable splines.
so lets not get hung up on fonts and standards that, quite frankly, were concieved in the 70s for large corporations who had thousands of drafters. Time to move on and embrace what technology offers us now and in the future.
But lets keep drawings. We will always need drawings until all our meeting tables are huge touchscreen panels.
