Dimensioning Arc Length in Paperspace
in Drawings
I am doing a tube bending drawing and I usually dimension the radius, angle & arc length on tube bending drawings. strucggling to work out how to dimension the arc length of the centreline in paperspace... Can anyone help?
2
So there is a document that shows how to so this . . .
https://cad.onshape.com/documents/673f5cf242983544f53711c8/w/4d091d8d8fd2881173d137e7/e/7f37e05e0571eb701a16b94d
But it involves a number of workarounds.
My ask of you is where these workarounds are 'needed capabilities', please as a Professional user, submit feedback tickets requesting the specific improvements.
Steps:
- Next - detail the sketch a you normally would (other than the arcs). We do not currently support the dimensioning of arc length - please submit an enhancement request (via the Feedback tool). To detail these, i used a note-with-leader and typed in the arc length (copied from the sketch). There is an 'arc-length' symbol available as part of the annotation drop down so that works.
I hope this helps you - PhilipYou can create a few edge to edge centerlines in the drawing and move the end points of this centerlines, so it looks like a single curve.
And then you can create the dimensions as you mention before.
