Is it posible to create a compression animation in an assembly? Cheers
tyson_moore
Member Posts: 1 ✭
john_mcclary
Member, Developers Posts: 3,998 PRO
If you are looking for an animated spring, then the answer is no.
otherwise, you can right click a mate that controls the degrees of freedom you want to animate, then click on the animate option6
