The Circular pattern dialog is very small
martin_bratbomartin_bratbo Member Posts: 1
When I attempt to make a circular pattern in sketch, the dialog is very small and only shows the green checkmark, so it is impossible to change the number of items and the angle. How can this happen, and more importantly how can the problem be solved?
  • emagdalenaC2iemagdalenaC2i Member, Developers, Channel partner Posts: 864 ✭✭✭✭✭
    edited May 2018
    First, I don't see any dialog in the circular pattern inside a sketch and I have no problems with that command
    But with that said, I try not to use the circular pattern inside a sketch. Instead I prefer to use the circular pattern feature, like in this example
    Un saludo,
