Exporting OnShape parts
yuval_taffyuval_taff Member Posts: 17 PRO
Hi,
What format type should I export my OnShape part as in order that I can import it back into OnShape such that I can still edit it (i.e. it retains all the functions of the original file)?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,894
    Hi @yuval_taff Onshape does not use files so there is no “file format” to export. Can I ask why you would want to do this?
