http://www.youtube.com/watch?v=eCgQu6sE4OA
http://www.youtube.com/watch?v=A41jkjFcuvU
I'm not fancy with the videos, but here's a graphic example. Lets call the two MCs created by selecting the highlighted surfaces MCA (RIP) and MCB. In the first scenario, you select MCA first followed by MCB. With a gap in between the surfaces, both Z axes point to each other as seen below. The offset is measured from MCB to MCA. This is important. The offset isn't just a number, it's a vector pointing from MCB towards MCA. Notice how this vector points in the opposite direction as MCA (the first MC)? That's why the offset is negative.
In the second scenario, you select MCB first. Now the offset vector points from MCA to MCB. This is still considered negative because it's pointing opposite to MCB (picked first this time.
In order to get a positive result for the offset seen below, you would need need click the "Flip primary axis" button in the mate dialog and also edit the mate connector definition of whichever one you picked first and flip its primary axis as well. I'm hoping they put a button in that does this last part for you.
MATE OPTION TO FLIP OFFSET/LIMIT DIRECTION
https://goo.gl/Scw5Z7
@larry_hawes, @brucebartlett, and @mahir thank you for your input and discussion on this thread thus far.
Twitter: @bradleysauln
