pattern to follow a shape for length
roland_horth
Member Posts: 3 PRO
Hi, trying to create a pattern of slots whose length is governed by a circle. Ie the overall shape of the 12 linear slots fits into a circle for a fan. In SW or Creo I would just make the length of the slot controlled by the round curve (so the only two slot dimensions would be the width of the sclot and it's distance from center), then pattern. Onshape just drives the pattern without changing the length so all are identical. Obviously I could just do all this in a sketch,.but seems like there should be a simpler way. https://photos.app.goo.gl/FIs9Gw6l4ZQrRbUz2
