Import from inventor
Could anyone give some advice please. I am making the the transition from Inventor to Onshape and it is going quite well ,learning something new each day, many times with your help. I am using a Mac for my Onshape but my Inventor runs in Windows via parallels desktop.As I am now a Onshape convert I would like to remove windows 10 and parallels from the Mac to free up space. As files from other drawing programs can be imported into Onshape my query is. I have several projects in Inventor, which would be classed as documents in Onshape. these projects contain drawings , Parts, Assemblies, and sketches. Can the project files be moved or imported into Onshape to prevent them and the work put into them being lost. Or maybe some other way of preserving the files to be used in Onshape at a later date.
Any help would be appreciated Best Regards Brian.
https://cad.onshape.com/help/index.htm#uploadfiles.htm?TocPath=Importing%20%26%20Exporting%20Files|Importing%20Files|_____0
Brian.
I need to migrate hundreds of different projects and have not found the correct method.
Can you give me some specifics to import successfully?
Does it import your feature tree or just the geometry?
