How do I orientate an imported STP model with my sketch planes??
Richard_HRichard_H Member Posts: 7 PRO
I've imported a STP model but I can't orientate it with my sketch planes.
I'm sure i'm missing something simple - or maybe not.
Instructions will be much appreciated.
Thanks in advance.
  • grochinogrochino Moderator, Onshape Employees, User Group Leader Posts: 44
    Hi Richard! You can use the Transform tool for this.
    https://cad.onshape.com/help/#transform.htm?
    If you need more help, please post a link to your document.
    Hi, and welcome to the forum.
    Have a look in the help section under "transform", specifically "transform by mate connector".  If it doesn't make sense please post a link to what you've got so far and somebody will help you out.
    Cheers,
  • michael_mcclainmichael_mcclain Member Posts: 198 PRO
    Depending on the imported model, whether it's with faults or not, I like to clean up the model, reorient it and export as a parasolid into a tab and reimport back into the same document.
    I've had issues with models that are so slow that they drag everything down with them so I find this to be a good method before I start using the file. It can keep the tree tidier and decrease Regen time on really troublesome files.
  • Richard_HRichard_H Member Posts: 7 PRO
    Thank you for your answers.
    I've had a look at 'Transform' but i still can't get the model to orientate.
    I've shared a link to the file and will appreciate any help.
    Many thanks.
    Hi, can't see a link I'm afraid.
    Cheers,
    Owen S
  • MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,059 ✭✭✭✭✭
    @Richard_H
    What is the link?
    Thank you Owen.  Orientated now....easy when you know how to!!
    Cheers everyone.
    Sure thing, it's like that here :)
    Cheers,
