How do I orientate an imported STP model with my sketch planes??
Richard_H
Member Posts: 7 PRO
I've imported a STP model but I can't orientate it with my sketch planes.
I'm sure i'm missing something simple - or maybe not.
Instructions will be much appreciated.
Thanks in advance.
1
Optionsowen_sparks Member, Developers Posts: 2,660 PROHere's one way to do it:-If you use the roll back bar in the feature tree you'll be able to see the steps. Shout if it doesn't make sense.Cheers,Owen S.Business Systems and Configuration Controller
HWM-Water Ltd6
https://cad.onshape.com/help/#transform.htm?
If you need more help, please post a link to your document.
I've had issues with models that are so slow that they drag everything down with them so I find this to be a good method before I start using the file. It can keep the tree tidier and decrease Regen time on really troublesome files.
What is the link?
