2d drawings arc lenght
in Drawings
Can you indicate an arc length in a 2D drawings. If you can i haven't found where it is yet.
Thanks!
john_mcclary Member, Developers Posts: 3,980 PRO
I am not by my computer right now. But I know you can in a part studio sketch.
Try clicking the two end point then mouseover the arc. I think that is the process if I remember right
EDIT:
After getting home I played with it for a bit. Looks like the answer is "no" for drawing arc length. You should fill out an Improvement request if this is something you need on a drawing.5 -
MBartlett21 Member, OS Professional, Developers Posts: 2,063 ✭✭✭✭✭
Mathieu_Guilmette said:Can you indicate an arc length in a 2D drawings. If you can i haven't found where it is yet.Thanks!
Make an improvement request in the category over to the right --------------------------------------------------------------->5
EDIT:
