Debugging "Some external references are missing"
tgunr
Member Posts: 45 ✭✭
After changing a sketch I got a bunch of errors. In one, I got rid of all the red constraints and everything looked fine but still the sketch is still reporting someone MIA. How do you track these down?
@tgunr - its tricky in any constraint based system.
A single 'square' for instance, has 11 constraints.
A complex sketch could easily have hundreds.
If any 2 conflict, the solver has no idea which 2 are the root cause and there are (usually) multiple solutions.
Tips- Undo the thing that just caused the problem.
- Roll back to an earlier microversion where it was good
- Check that you didn't automatically create a constraint you didn't want (h and v are the two usual guilty parties)
- Use the shift key when dragging entities (prevents new constraints from being added
- Delete suspect constraints (you can always put them back).
Philip Thomas - Onshape8
Have you tried turning the sketch constraints on with the checkbox on the sketch dialogue, this helps to see all the constraints?
Has it lost the sketch plane?
Share a link and we can take a look.2 -
Philip Thomas - Onshape8 -
ps - the message 'Some external references are missing' usually means that an edge was converted into a sketch or a dimension attached to an edge that is no longer in the model. (most common case).Philip Thomas - Onshape1
Is there a red dimensiontgunr said:After changing a sketch I got a bunch of errors. In one, I got rid of all the red constraints and everything looked fine but still the sketch is still reporting someone MIA. How do you track these down?0 -
Another check to help is to zoom out to see all entities of the sketch. Sometimes editing a previous feature can throw a reference far away from the desired sketch.
