Debugging "Some external references are missing"
tgunrtgunr Member Posts: 45 ✭✭
After changing a sketch I got a bunch of errors. In one, I got rid of all the red constraints and everything looked fine but still the sketch is still reporting someone MIA. How do you track these down?
    Have you tried turning the sketch constraints on with the checkbox on the sketch dialogue, this helps to see all the constraints?
    Has it lost the sketch plane?
    Share a link and we can take a look.
    ps - the message 'Some external references are missing' usually means that an edge was converted into a sketch or a dimension attached to an edge that is no longer in the model. (most common case).
    Philip Thomas - Onshape
  • MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,064 PRO
    Is there a red dimension
    IR for AS/NZS 1100
  • billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,153 PRO
    @tgunr
    don't forget to check the plane you created the sketch on. If it's no longer there, you'll get an error and will have to re-route the reference to another plane.
  • corvus_engineercorvus_engineer Member Posts: 1 PRO
    Another check to help is to zoom out to see all entities of the sketch. Sometimes editing a previous feature can throw a reference far away from the desired sketch.
Howdy, Stranger!
