Issues with solving an assembly
isaac_oneil
Member Posts: 15 ✭
I am trying to solve an assembly so that when I animate it I know it will function correctly. Needless to say I don't know where I screwed up. its supposed to act like a scissor lift that can tilt left. Link below.
https://cad.onshape.com/documents/8b6da23130a9dee535af0c96/w/f34a388fedf1c58e1269dcd5/e/c75acede3d33cc97cd1c1390
larry_hawes
Member Posts: 478 PRO
Looking at your document there appears to be 2 Assemblies 'Desk Lift Mechanism 2' and 'Assembly 1' but hard to tell what is meant by 'it' is supposed to act like a scissor lift. What is the 'it' you are referring to, and what direction is 'left'?
Is desk lift mechanism 2 supposed to act like a scissor? And tilt left? Or is Assembly 1 supposed to act like a scissor and tilt left.
Another thought, is there a way to represent both conditions for the scissor? Closed in the collapsed condition, and open in the extended condition. Could be anything from stick figures to your current doc with mates suppressed and the parts moved in to both positions to get a better idea of how the assembly is supposed to behave.
That way it might be easier to get some help on how to get the assembly to behave between those 2 conditions.5
