Copy
brian_pinder662brian_pinder662 Member Posts: 119 ✭✭
Can anyone advise please. I am trying to copy a part in an assembly. the part needs to be copied 236.5mm above the original. Is there away to copy and paste in exactly the correct position. any help would be appreciated thank you .
Regards Brian
  • brian_pinder662brian_pinder662 Member Posts: 119 ✭✭
    Not tried it yet but feel sure either of your replies is will do the trick.
    Once again many thanks Brian.
