Linear pattern
brian_pinder662brian_pinder662 Member Posts: 119 ✭✭
Having created three linear patterns,I need to make slight adjustments in context to the copies. Can anyone say if this can be done without effecting the original. I have selected new when creating the patterns but trying to make adjustments to the copies reflects in the original. Any advice would be appreciated.
Thank you Brian.
  • brian_pinder662brian_pinder662 Member Posts: 119 ✭✭
    I would like to thank everyone for the help given,
    All the best Brian
    @brian_pinder662
    It would be easier to diagnose the problem if post the URL to your document.  It's possible that all the instances in your assembly are referencing the original rather than the copies.
    Would post URL willingly if I new how, something I am not familiar with thanks for your advice.
    Is it possible to cancel the associativity between the copied instances and the original. To be able to make adjustments to the copies  without them reflecting in the original. Thanks Brian
    https://cad.onshape.com/documents/1ac8b7a7ef3f5ab5fd9e36ba/w/25c6d985e52a5e282f7cd05b/e/4a84473fb9190a5f396f1114
    Here is the URL for the Assembly, The Helical Handrail At the start of the 2nd flight is the original, directly above are the copied patterns which as you see the handrail I would like to adjust without any alteration to the original. You will no doubt see other discrepancies which I would like to discuss sometime later. Thanks for your patience.      Brian
    All the best Brian
