Linear pattern
brian_pinder662
Member Posts: 119 ✭✭
Having created three linear patterns,I need to make slight adjustments in context to the copies. Can anyone say if this can be done without effecting the original. I have selected new when creating the patterns but trying to make adjustments to the copies reflects in the original. Any advice would be appreciated.
Thank you Brian.
Thank you Brian.
Optionslana Onshape Employees Posts: 699@brian_pinder662
In order to post your document url please open your document, copy its url address
And paste it in your forum post. This would allow other users to see your document and answer your question.5 -
Optionsphilip_thomas Member, Moderator, Onshape Employees, Developers Posts: 1,381@brian_pinder662 - I will give this a shot to try to help you.
Your document is very impressive.- Re patterns - yes you may delete any instance without breaking the pattern.
- You may modify any instance of a pattern without breaking the pattern or 'changing' the original.
- I see that you have used a lot of in context and 'make reference to' instances. If you want to change one instance 'in context', instead of just referencing the face or edge, you can use transform/copy-in-place to create an exact duplicate that you can modify. When you return to the assembly, insert the copied/modified part and hide the original.
If you have any additional specific questions, please feel free to askPhilip Thomas - Onshape5 -
Optionsbrian_pinder662 Member Posts: 119 ✭✭I would like to thank everyone for the help given,
All the best Brian1
It would be easier to diagnose the problem if post the URL to your document. It's possible that all the instances in your assembly are referencing the original rather than the copies.
https://forum.onshape.com/discussion/9107/forum-post-checklist
Cheers,
Here is the URL for the Assembly, The Helical Handrail At the start of the 2nd flight is the original, directly above are the copied patterns which as you see the handrail I would like to adjust without any alteration to the original. You will no doubt see other discrepancies which I would like to discuss sometime later. Thanks for your patience. Brian
All the best Brian
