Ability to select sketch coordinate system when creating
I noticed that no matter how coordinate system of the plane was defined when sketch is created on the plane it always created by newSketch( ) function. I would like to have more control under the orientation of coordinate system of the sketch (be able to create user defined sketch by newSketchOnPlane()). I think this functionality can be extended by allowing user to create sketch by selecting mate connector instead of planar face. Thus one may take control under coordinate system of the sketch.
https://cad.onshape.com/documents/8331d15630b35a24c141111b/w/0cbd83b60224be56f674efc3/e/f4cc466621b6b86b2fb058d5
don't know why this post was mooved from improvement requestst, because it is about extending functionality of built in sketch tool
We adjust the coordinate system deliberately to minimize "parametric surprise" because for a random planar face, the internal coordinate system is not predictable. I suppose we could make an exception for mate connectors, but what is your use case? Fancy feature patterns?
