Need to change extrusion height of 16 different parts with a Variable or equation
paul_bartlett
Member Posts: 98 ✭✭
This is the part I am referring to https://cad.onshape.com/documents/19ccedfa79bcaae737fc2b78/w/57ef42aa3da09539b7ab6acb/e/595ed0d6e4e6dca34a193ead
I extruded each segment one at a time as they need to be different parts. I wold like to change the extruded height of all of them at one time. Is there a way?
jon_sorrells
Onshape Employees Posts: 52
You could extrude 1 part, then pattern it 16 times. That way you can edit the one extrude, and it will change all the parts. Make sure the pattern is set to 'New' so it creates new parts instead of merging them with the existing one.
5
Take a look to the document
https://cad.onshape.com/documents/35e4812de6a34ebfa52c6115/w/3eab0c225f16cca810cee198/e/26f6ce5a49f114f6be25d6ab
