Angle mate in assembly
I know its probably easy but I can't find how to angle mate these 2 rings one to another using the segment lines or another way. I need 7.50 degrees between each ring using the segment lines . There will be 25 rings when done. Each one will need this mate
https://cad.onshape.com/documents/47f8ecb372dd67b4c4fb5112/w/ba34d8bff1f38e186692569e/e/2df4690c80f70b021a09536d
mahir Member, Developers Posts: 1,315 ✭✭✭✭✭
Just add 7.5deg as both the min and max limit of the revolute mate.
5
